Problems with Infrared sensors
We are a high school class using the Boe-Bots in our project for the year. We are starting to use the infrared sensors to make it so the Boe-Bot will be able to manuever around objects etc.. The sensors were both working on two different Boe-Bots, but now the left ones on both Boe-Bots aren't working anymore. We have tried testing the breadboards with a multimeter and everything came up fine so we are perplexed. Any help is much appreciated. Thank You.
The attached code is right out of the book. We used it this morning in our class.
TestIrPairsAndIndicators
The other program may also be helpful.
RoamAndSniffBoeBot
Hope you do not have to pull everything and re-wire it....
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
