SX?B help
Are the SX/B help files available in PDF format? (Mac user)
also-check out the greyhill 61c series rorary encoder-optical switching and push button contact allowing twirl to select and push to set
Jon Williams
Dallas, TX· USA
That would be excellent if a PDF version of the manual was available, as I like to have a printed version
for reference as I do most of my coding on the train !
Many thanks
Tony
Jon Williams
Dallas, TX· USA
I did a quick Google search for a CHM to PDF converter and I managed to create a very good PDF
but the hotlinks on the Commands section did not come through. Rather than you creating a seperate PDF
of the manual, this kind of conversion might be the way to go - It only took me minutes to download the program
and convert the help file.
I'll keep looking for a package that will do a better conversion and let you know which one works. You could then use
it and produce a PDF available for all. What do you think ?
Tony
Jon Williams
Dallas, TX· USA
