BS2 and 2816 EEPROMs
i'm working on a project with a BS2 that will require an extreme amount of data to be stored and retrieved. having a few 2816 eeproms on hand, i was thinking of using·one of them to store the info. before i reinvent the wheel, i thought i'd ask the guru's if/how this has been accomplished in the past and if anyone had any constructive advice for me.
thanks
B01nK~~~
thanks
B01nK~~~
spence
k4kep
No hassle with doing SEROUT/I2COUT/BitBanging/Shift-registers or anything.
for the pure reason of "it can be done", i'd still be interested to know if anyone's interfaced a 2816 to a BS2...
B01nK~~~
I have never heard of a cpu that could alternatly use either 8 bit program memory or 16 bit program memory. Usiually it is 1 or the other.
The solutions cubed serial memory uses a non volital(nv) ram which is somewhat similar to eerom with a cpu on board to handel the serial to parallel and parallel to serial conversion.
73
spence
k4kep
The BS2pe contains 16 banks of 2kb. Eight of these banks can be used for programs a la the BS2p and others. The remaining 8 banks are used for data storage exclusively and can not contain programs.
Jim
where did you find doc specifically on the data only 16 k eerom for the 2pe?
I have searched everywhere including the download 2.1 basic stamps manual and founf nothing?
73
spence
k4kep
You can find it here, among other places:
http://www.parallax.com/detail.asp?product_id=BS2PE
It also appears in the Stamp Comparison document which can be downloaded near the bottom of that same web page.
Bruce Bates
