stop command
Is there a built in key that can be pressed while I'm running the Basic Stamp Editor v2.1 that will send the STOP command to my BS2 immediately?
Jason
Unreal tournament 2004 rox
Jason
If I am running a program, and something acts up, I quickly click on that tab then select run, which downloads the new (blank) program and halts whatever was going on before.
--==<{Chris}>==--
Ben Damon
And may God Bless America!
I currently just dowload a program with only the STOP command in it to stop everything.
Thanks for all of your help on my original question everyone.
Jason
·· Using end isn't always a good idea.· Many people find out the hard way when their program ends, and their project starts doing whacky things, due to the what happens after and END statement.· Every 2.3 seconds, the OUTPUT pins will switch to INPUT for 18ms.· This can cause often undesireable effects depending on what's connected to the pins.· Just something to bear in mind.· Take care!
--==<{Chris}>==--
Just something to keep in the back of your mind for in the future when you see such a post...·
--==<{Chris}>==--
