Digital dc pump control
Hi!
I would like to control the speed of a small DC diaphragm pump by varying the voltage to it from a stamp. I can rig up a digital to analog converter but am not sure how to handle the power the pump requires. I guess what I need is some kind of voltage follower that will handle the motor current. The pump will use up to about 300mA at a max voltage of 6V.
Any suggestions would be much appreciated. Is there a single component out there that will do this for me?
Dean
Dean
--==<{Chris}>==--
I remember mucking around a long time ago trying to get a friends "spy recorder device" to record for more than the 90minute tape allowed.· Playing with the voltage did a little bit....but I hit the cutoff voltage before I slowed the motor down enough.
Wouldn't PWM be more what is needed for speed control?!
Steve
http://members.rogers.com/steve.brady
I will look into the transistor idea Chris. I just don't play with analog electronics enough to know how to do that off the top of my head. I will take myself to school to figure it out.
Perhaps I will try the PWM idea also, using a transistor as a switch?
Dean
Steve's suggestion is usually better for driving motors.· It's certainly more efficient.· And you could use a pre-fab motor controller.· Parallax even carries some.· My suggestion was simply based on your need to vary voltage.· You need to decide what's the best course of action for your project.· I don't know the details.· Good luck!
--==<{Chris}>==--
