I'm not certain what you mean by 'right' side on it.
(A reference based on the pin numbers would be helpful)
But one of the 8pin chips is the voltage regulator, and the other is the EEPROM.
Are you driving any other chips from the onboard 5V supply of the BS2p?
There are some production related voltage differences between regulators.
If it is the case the the small Stamp regulator has a little higher output voltage than the external then the whole current for your application will be sourced from your onboard Stamp regulator. Then can cause the little regulator to get hot.
The middle right 8-pin SOIC - next to pin19 - may be a regulator.
I have a piggy back plugged in to the Stamp socket and then the Stamp.
The piggyback has its own regulator and is driven by pin 24 - Vin.
Pin 19 - Vdd on the Stamp - comes from the external regulator so any thing you connect to pin 19 would not affect the Stamp's onboard regulator
Sid Weaver
Do you have a Stamp Tester?
kelvin
Just an idea,
Klaus
