small robot chassis ideas?
I am in the process of building a small robot that uses steper motors as the drive system. These motors are fine for the drive, they have 3200 g-cm of torque and are going to fit inside a chassis thats (idealy) 4" wide, 6" long, and 3" high, which fits the motors nice and snugly. The problem is the chassis. I need something that I can drill precise holes in and is perfectly straight with no tapers. The radioshack plastic project boxes looked like an option for a while, but they were tapered and the steppers would be at enough of a slant to screw up their precision, which is what this robot is being built for. In my past few robots, I have cut and bent sheet aluminum into a U shape and mounted continuous rotation servos on the sides (much like the BOE-bot, but a little larger). That will not work this time, because my bends tent to be tapered or slanted a bit, so I am looking for sugestions at to what I should use.
Justin W.
Justin W.
At Crankorgan.com you can see it used for homebuilt CNC milling machines. Look at his "Brute" model.
Don't forget about printers they have some decent framing inside them as well. You are looking for 4x6x3 thats pretty close to the frame which holds CDROMs in.
Good luck
Johnny
