SX20AC/SS / SX52BD soldering
Hi all - Looking at my latest creation - or the paper-napkin schematics for what might be - I thought to my self: Why on earth·am I still using those "huge" DIP chips, when SSOP is like four times smaller, and has a lot more techisc kind of look on a PCB (i.e. the SXKey lookes more cool - I think - than the SX Tech board it self).
So, young and naive as I·sometimes pretend to be, I bought·a box of·10-cent 20 pin SSOP chips (not the sx, but some cheap gadgets witch functionality I don't even care to check out), just for verifying if I was in fact able to solder the tiny things on to a copperclad board - wich I wansn't
Does this mean I'm too fat-fingered to solder SSOP components or do people in general just avoid SSOP unless they have a machine to do the soldering?
If the first (fat-fingered) version is closest to the truth (i.e. if SSOP _can_ be hand soldered) is there a kind soul who could point me towards some material (online or books) on the subject?
Why do·they call it a spacestation? There's hardly "space" for anything in there.
the way i solder SSOP components is by lathering the pins with solder. (just glop it in)
then use a copper wick to wick away the excess solder.
James Newton, Host of SXList.com
james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
Thank you James, I'll try both wick and the sxlist-walkthru [noparse]:)[/noparse]
Post Edited (Lemon) : 2/18/2005 10:16:56 PM GMT
Second is using solder paste and heating the pad only.
Both have thier advantages and drawbacks, James' link talks about some of the issues. First and foremost if you doing hand soldering, you need a quality, temperature settable iron with a very small tip.
Thats a lot of clips paul [noparse]:)[/noparse] actually more than one looks interesting.
Liberal amounts of liquid flux.
1.Tack two opposite corners
2. Then with a small amount of solder on the tip, "wipe" it across the leads. ( I did not yet see the video suggested in a previous post, but assume it does the same/similar)
3. Clean any bridges with solder wick
When I return from this business trip in Japan, I will snap a photo of my amature work and post it.
Btw. did I mention I'm quite a cavetroll with a solderingiron - but it's about to change, or so I have descided.
I create my own boards with the Press-n-Peel stuff and I unfortuantly don't have any way to add a soldier mask, so the soldier drag method has not worked out so well. However, I do use the following technique: www.circuittechctr.com/guides/7-3-1.shtml
with the a few changes:
1) I make the pads for the smt only as large as the pins
2) Before putting the chip on the board, I tin all of the pads with very little soldier with the exception of one pad the has some extra
3) I use tweezers to hold down the chip (straddling the board when the chip is close to the edge) and touch the iron to the one pin with the extra soldier and check alignment
4) For the rest of the pins, I use .38mm 60/40 soldier, touch the iron to trace paths close to the pins, but I leave room to touch the solder on the trace path between the tip and the chip.
The trick here was the tining of the pads before putting chip down. I have found in the past that trying to get the solder to flow up under the path and onto the pin would frequently fail due to a lack of heat transfer as only a small spot on the pin would actually touch the copper. With the pad lightly tinned, it seems to collect where it can transfer the heat to the pin.
Ok, so admittedly, I am not a professional and I am sure I would get beat-up for not using flux, but the joints are shiny and seems to be quite strong.
If I ever do slip and add too much solder and it jumps across pins, I use soldier removal braid on those pins. I try to time it to leave a little, but usually (as you hinted) end up taking it all up and just redoing those pins.
Good Luck
Jim
Only draw backs are that its 8mil min (proper pads for 8mil chips is 6mil) and its a 2 week turnaround.
I have just made a perfect connection of a 20-pin SSOP "thing". Using a LED and a 6V battery, I have verified that there are no bridges between the pins. I found that I get the best result using a generous layer of a German "l
A "pro" would tell you that this is a mediocore job at best. There is far too much solder on the pins.
Post Edited (KenM) : 3/4/2005 4:00:13 AM GMT
I noticed the chip is labelled SX18AC/SO - is that an older version that is not available anymore?
Looks like you have something between pins 8 and 9. Might just be a piece of lint ???
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
I have been using that guy for several months so far w/o a problem.
k
For a project that will (has been) sold, where I may have to build 6 to 10 of an item, I prefer a DIP package.
For me, a DIP package can be soldered into a board much faster and easier than I am capable of doing surface mount, and you know what they say.....time is $$.
My $0.02
Ken
But Im getting the hang of SSOP soldering anyway, there by saving another inch of valuable space (and weight).
SMT is also a question of the developer's age. I have met younger people who were able to solder SMT components to a PCB in an almost dark room. When I try to do this, I need
1st - my glasses
2nd - plenty of light
3rd - a magnifying glass
4th - at least one drink to calm down my hands
5th - a small tip on my soldering iron, and finally
a lot of good luck
Greetings from Germany,
G
(I also need the right amount of coffee - too much, or too little, and I shake all over the place [noparse]:)[/noparse]
I scored one of these http://smtinspection.com/mantis_detail.htm on ebay a while back - they're superb.
For documenting stuff, I've also got an old Intel QX3 play microscope - now superceded by
http://www.playdigitalblue.com/products/qx5/info/ which looks a lot better (much higher resolution, faster frame rate, cheaper)
Probably not good enough to work under, but definitely a good inspection tool, and $80 isn't too bad at all.
Steve
this was a good tip - I have just ordered one of the Digital Blue microscopes. When I have it here, I'll give you a report on how useful it is.
G
1st·- plenty of light (or something to keep the soldering iron away from my fingers).
2nd - A nice balance of water and (dare I say tobaco) to keep my mind focused and the smell of burned fingers from reaching my nose.
3rd - How do you do with just one drink? My hands would be out of control with a drink in one hand, and only a solderingiron in the other to keep the balance. Two drinks for each hand will definatly even out the weight ratio of left and right hand and keep'em both steady. But not 6 drinks thou, since the last to goes straight to the forehead and pulls down towards the solderingiron, leaving a "Harry Potter" style scar.
My trick is to "ping" the holes first to create a small divot so that the drill does not have
a tendency to wander. I'm not sure what the proper name for the tool is, but I could
post a picture I guess. It basically is a 'pick' with a very sharp point at one end, and
a large base at the other end that you can hit with the palm of your hand. It takes a
little bit more time, but it does the trick.
Also for the drill, I have a jeweler’s variable speed drill with a snake attachment.
(speedometer cable with a very small drill chuck at one end, motor at the other.)
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
Do you have a dremel? how about getting a dremel drill press?
Beau:
I do in essence·the same thing, I use a hand drill with a 1/32" bit and the trigger speed control set to barely rotate at full depress, then I put the bit in the dremel and drill away. I quickly learned that even at the lowest speed, the dremel will skid across the surface without a divot. I use the dremel because it is much easier to control by gripping with both hands and doing a straight plunge. Though a jewelers drill with snake attachment would be even easier.
