Writing to EEPROM
I am prototyping a new EEPROM.· When I enter the number of packets to receive and store, I would like to automatically write the number of packets to the Stamp EEPROM so when I want to read the stored data the Read routine will read the Stamp EEPROM and get the number of packets to read out.
I wrote:
WRITE 0, word a········ 'a was previously entered as 25
After loading and running the program, I looked at the memory Map.· There was nothing there.· Am I misunderstanding the use of WRITE?· If it does not appear in Stamp EEPROM and is not there when I reboot, this effort will avail nothing.· I do not want to write a DATA statement and reload the program everytime I change the number of packets to read.
Sid
Sid
You COULD use a 'DATA' statement, that would only be written by the BS2 IDE when you Program the chip -- you are free to change that value via WRITE on-the-fly, and it will retain what you WRITE.
Rebooting the chip does not erase the EEPROM, nor does it 'refill' the DATA statements, so that would work for you.
Jon Williams
Dallas, TX· USA
If I tell the program I want to store 300 packets, and start it running, I can then go back into the program and write:
DATA word 300
This shows up immediately in the Stamp EEPROM - no necessity to reload.
So I guess I have found the best possible answer.
Sid
So when you say "DATA word 300", the Prediction is updated -- but your BS2 is not.
