Magic Crystals or Enchanted Key
wow what a lamo subject.... eh uh
i recently purchased the SX Tech Tool Kit and was experiencing some problems with a program. i plugged the 50Mhz resonator into the proto board and generated other frequencies with the key and the sx wasnt working properly. so i tugged the resonator out of the board and swapped out the sx chip and everything seems fine now.
can i use an external resonator & the sx key at the same time?
did i do any permenant damage to anything?
or did my program fail for some other reason?
League Bowling.... it's not a sport, it's a way of life
There can only be one frequency generator to the chip at a time on the prototyping board - the resonator or the SX key.· I have frequently plugged the SX-Key into the board with the crystal attached and did not sustain any permanent damage to the chip, the SX-Key or the resonator.
The good news is that it looks like the design of a new prototyping board is attempting to require the removal of the resonator before one is even able to plug in the SX-Key (see earlier thread).
Jim
...Could the demo boards have a small toggle switch added right between the Resonator and the SxKey port? SPDT. I believe that only the driven OSC pin would need to be switched. One way and the SxKey is running, the other way and the Resonator is in control...
James Newton, Host of SXList.com
james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
Paul
