DS1822 1-Wire thermometers Vdd
I planning to install several DS1822 1-Wire thermometers on extended outdoor wires. The data sheet says they use typical 1 ma active. May I use a resistor, say 1k, inline with DS1822 Vdd to protect the Stamp voltage regulator from possible shorts with ground?
Jon Williams
Dallas, TX· USA
If you put a 1K in series with the stamp pin you may have trouble because the stamp will not be able to pull the data line to ground level. If you put the 1K on the other side of the pull-up then the ds1822 will not be able to pull the data line to ground level.
I would think a 220 ohm, would provide protection enough and not affect the levels to badly. If you are using a 4.7K as a pull-up then the stamp could pull the line to down to 0.22volts.
Bean.
Check out· the "SX-Video Display Module"
www.TerryHittConsulting.com
Bean.
You both beat me to the punch. I couldn't remember my password and had to wait for the e-mail (Great support function by the way) to remind me. I had a similar problem and used the experimental mode. I am using a four wire shielded cable. I will use the cat-5
next time.
Sofa
