scoreboard project help
I'm using the NX1000 board with a BS2 stamp and i'm trying to do a scoreboard project.··I want to know how can i run a clock, 3 counters, and 4 switches.· It looks as if there are only 16 pins available, are there more?· Right now, the clock takes up 11 pins, leaving only 5 for the counters and switches.· I hope this is enough information, please help!!!
Take a look at the 2 PDF documents found on this page:
http://microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1490&filterID=529
They have some EXCELLENT PIN conservation ideas. The designs are not for Basic Stamp, but should work with any microcontroller.
Also search through other designs on this page:
http://microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1469&filter1=function
there might be more usefull information in some of these subsections.
And they can be daisy-chained. If you've got the power supply, and easy was to control 7-segment displays is to daisy-chain a few 74HC595s -- again, StampWorks shows how.
Jon Williams
Dallas, TX· USA
