Wireless sensor's and BS2
Hello
I'm new with Basic Stamp, but I see it's a very nice component for use as a datalogger. I want to make many wireless/ remote sensor, like temp, current etc.
Any have a suggest to very small transmitter low current and a resiver that can be used for read many transmitter.
I think it will be the same system as a weather station.
Thank you
Jonny K. ( Italy)
Thank you
Jonny K. ( Italy)
What sort of distance are you planning between the transmitters and the receiver? Anything over a few hundred feet will probably require a license from the issuing authority in your country.
The other issue that you will have to sort out is data collisions between competing transmitters, both/all transmitting at once.
Bruce Bates
No I only like to be able to messure the temp at about 50-100m
remember that when a modules specifies a distance, it is light of sight distance, if your signal must go through walls or other obstructions it will reduce the modules effective range.
Post Edited (Paul Baker) : 2/15/2005 4:20:18 PM GMT
I think you are limit to a watt or less (definately no more than a couple watts)....but have no fear...there are guys that transmit hundreds of miles on a couple hundred milliwatts (different frequency of course).
A friend of mind recently put in some wireless units in the basement of an old warehouse building.· Big thick walls with lots of reebar.· Well, he couldn't pass signals through walls, but the hallways acted like waveguides.· Luckily he was using some digital units so the 'echo' (or second trip) were ignored with the CRC.··· He had to play with latency and preamble but it worked....so long as nobody closed the door in the one room! haha
Steve
http://members.rogers.com/steve.brady
I also found this other forum soo I will continiu in there..
Mille grazi
