SRF04 Ultrasonic Range Finder
On my new car I installed a front air dam that sits close to the ground.·It really looks nice but since it won't clear a curb without being torn off I would like to install a SRF04 range finder in the air dam for obvious reasons. Anyone know of a way to semi waterproof this unit? There must be a material that won't affect the operation since a lot of these new vans have them on the rear. Anyone have suggestions?
Thanks in advance
Thanks in advance
not sure what they eventually went to.
The SRF's are basically small speakers.· So, if you take a speaker and put it in a waterproof box....does it work?!· Not well, as it needs to move air to create the sound.· So 'boxing' in the SRF won't do.· And any 'waterproof' speakers you come across are no different than other speakers except that their materials are all coated and covered, but it's exposed enough that it's action still moves air.
I know there are cars that use ultrasonic...but they must have a weatherproof casing that still allows them to work.· They're probably more costly than the SRF's and may decay after a winter of salt and water.
Have you thought about IR?
Steve
http://members.rogers.com/steve.brady
I was looking to use the SRF04 since it could be mounted with two small holes and go almost unnoticed. The factory units are not exactly what I was looking for.
I don't know where you live, but if you're in a snow belt, ANY moisture that settles in there will corrode wires and the tin can casing of the ultrasonics.
I have to seriously pressure wash the truck every couple weeks to get all the salt debris off.· You'd be surprised where the stuff gets.
Anyhow...off topic.· DEFINATELY be sure to weatherproof your cct....run wires out to the sensor and maybe you can get away with replacing the sensor heads after a couple winters.·
don't get me wrong...the SRF is a perfect choice for your application....but the weather will get it.· (think the wicked witch and Toto..."and you're little dog too"...ok not that dramatic maybe).
Certainly what Forrest says about the ones car manufacturers use....that's something you'd want as far as it's sealing.· But they'd get $$ I'd imagine!
Steve
http://www.robot-electronics.co.uk/shop/Ultrasonic_Rangers1999.htm
I have bought one for experimentation.·It·has a sensor that it's surface seems to be rather water resistant. Maybe you could modify one·and place the sensor apart from rest of circuit which you could protect easily.
Michael
SensComp makes a series of piezo electric transducers which are waterproof www.senscomp.com/kseries.htm. They have an evaluation kit www.senscomp.com/specs/piezo%20kit.pdf which has a sample of all their different piezo units.
From my research, the SenseComp units look like to best bet, but I've not ordered them yet as I'm trying to limit myself to one project at a time.
Jim
It's not ultrasonic....but just curious!
Steve
Jim
