Resistor lookup?
I have several resistors that were given to me in a box of parts and I do not know what they are. Is there a way to find out what they are from a website or something? I don't have the manufacturer name.
The first one is a flat light blue color with 4 solid color bands on it, they are red, green, silver and gold in that order.
The seond one looks more like a capacitor in shape (flat ends, not tapered), it is black and has a silver band on one end and has 'MEC' on one line and then on the next line it has '1N4001'.
Jay
Jay
bugg
I think I know what I'm doing...
...Maybe...
It is a good unit. I know of 10 in this immediate area. One in use over 4 years on the original 9 v battery.
It has all the common scales you will probably need for years to com.
The 1n4001 may be a diode. If so, the silver bar across one end is the cathode.
73
spence
k4kep
bugg
...Maybe...
red green silver gold = 0.25 Ohm +/- 5%
the black with siver band is a diode: http://rocky.digikey.com/WebLib/On-Semi/Web%20Data/1N4000%20SERIES.pdf
typically used for rectification purposes
Paul that is exactly what I was looking for, thanks.
Jay
Yes it is, the link rocky.digikey.com/WebLib/On-Semi/Web%20Data/1N4000%20SERIES.pdf that Paul provided gives the exact specs of it.
Jay
http://forums.parallax.com./forums/default.aspx?f=5&m=63033&g=63037#m63037
--==<{Chris}>==--
Jay
