Components
Hi all,
I've aquired two stepping motors for my wire winder project. I'm going to pickup a darlington array this weekend. While I am at RAE I would like to pick up anything else I need. For example I'll probably buy 50 or so 470 omh resistors, what other common items should I pickup? My project is to finally include two stepper motors, a 5 button control panel, and an LCD. I guess mainly I'm just thinking caps and resistors and other odds and ends. Trying to stock up on my parts.
Johnny
Johnny
Four to eight LED's make nice debug indicators.
A 470 Ohm resistor array is nice. These are SIP or DIP chips with multiple resistors in them.
A few small 0.1 uF capacitors for decoupling are good.
10 Kohm resistors are nice for pull-ups and pull-downs.
Look at the "Analog and Digital Interfacing" book, or the BS2 manual, for how to debounce a button. You'll need some small parts for that.
their prices. BTW, there is a minimum order-$10.00.
bugg
I think I know what I'm doing...
...Maybe...
Post Edited (bugg) : 2/16/2005 1:06:26 AM GMT
Dave
I've picked up a couple capacitor packs and have no use for them.· There never seems to be an oft used value in there.
If you see a cap pack with all electrolytics...grab them.· Don't bother with it if it uses some old ceramic disc types...only my opinion.
120ohm
1kohm
10kohm
220ohm
2.2kohm
22kohm
330ohm
3.3kohm
33kohm
470ohm
4.7kohm
47kohm
5kohm
5.5kohm
56kohm
those are what I'd shoot for.· You probably·won't need anything in the meg range...but maybe pick up a couple 100kohm·and remember, you can put 2 (or more) resistors in series to get the value you want (adding them) and same goes for putting them in parallel (parallel resistor math applies--quick tip, the total parallel value of more than 1 resistor is never larger than the smallest single resistor value in the parallel cct.).
Pick up some pots too.· 1k 5k 10k and maybe a couple 10-turn pots for more resolution.
0.001uF/0.01uF/0.1uF/1uF/10uF are the more common caps you'd need (electrolytic).· The voltage rating need only be more than what you're cct supplies....so go for 50V caps unless you want a small design and are only using 5Volts in your cct.
Some 12V/5V relays (automotive relays are cheap)....some opto's and LEDs.
I could go on....[noparse]:p[/noparse]
What you don't get this trip, you can get next trip....cuz you can NEVER make enough trips to an electronic shop!
Steve
http://members.rogers.com/steve.brady
kelvin
http://forums.parallax.com/forums/default.aspx?f=15&m=58604
Johnny
kelvin
The only place i've seen them was on Digikey.
"Flat Flex Cable Assemblies" Page 45-46 from the May-Aug 2004 Catalog. But they are somewhat pricey there.
3 or 4 pin Female to "Solder Tab" (thats what digikey refers to them as, tabs are small enough to be inserted into breadboards, but still dont bend.
digikey product #s A9BAG-0404F-ND for example.
But your requirements of .1" spacing, bread board insertability I can understand you not wanting to use this. One thing to keep in mind is that the solder tails have a width of .026" (.66mm), I dont know what gauge wire this corresponds to but they may be too wide to fit into a standard breadboard (someone else would be able to better help you with this aspect).
I'll explain what I do: I still use standard ribbon cable for breadboarding when the situation warrants. I strip 1/4-1/2" off the end, take a razor and carefully split the individual wires. I then tightly twist the ends. If I'm in a rush, I just carefully insert them into the board at this point. If I have extra time, I solder each exposed wire with just enough for the end to act like a solid wire for easier insertability. By doing this I can crimp an appropriate connector on the other end for plugging into another board or do the same to the other end if plugging into another breadboard. The advantage of this method is that when you move from prototype to a pcb layout you can simply cut off the ends which have been split attach a crimp connector and use the same cable in your final version.
Alternatively you can use 0.1" pitch ribbon cable like the molex/woldom cable on page 49 of the digikey catalog, those would also require solder to stiffen the ends, but wouldn't require spliting the cable out to fit the breadboard. But you cannot use standard crimp connectors on them.
If you only need 4 wires and you dont plan on moving past prototype, I would consider just sticking with individual solid wires
Post Edited (Paul Baker) : 2/15/2005 5:10:05 PM GMT
This is only an example, there are many ways to use this, as if you don't need all the pins, some can simply be pulled out. And there are different sizes of connectors. Just wish a straight 5 or 8, etc. connector was made instead of the double configuration, but i can live with it.
When you are wiring the ribbon cable into the compression fitting, be aware of what side of the connector you want contact with. There is a small arrow one side of the connector that points to the first pin. Anyway, works for me and saves playing around with stripping, soldering and twisting the ends of wires, and provides a nice connection that won't come out by itself. And best of all, the cost is small.
kelvin
