Motor shaft
Hi all;
I'm looking for a way to "extend" the shaft of a stepper motor. It is to be connected to a shaft which probably will be larger then the shaft of the motor itself. Does anyone have any experience with this, if so what was the solution. If anyone knows of any companies which supply this magical part I seek maybe you could post the link too!
Johnny
Johnny
bugg
I think I know what I'm doing...
Well, Jonathan, I'll be of more help. You're looking for couplers/couplings, and they're fairly common. Some couplers have the same inner diameter (ID) on both ends, and some of different ones (as in your case). There are also many many variations, some that are $20+, and some that are around $2. I normally get them from www.sdp-si.com, but they're site seems to be messed up at the moment.
Good luck! Let me know if you have any further questions.
kelvin
www.jameco.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10001&catalogId=10001&langId=-1&categoryId=12332
