Emulate a UART Over an I/O Expander
I have a Philips PCF8574P 8 bit I/O expander on my I2C bus. This expander connects to a DMC-8 motorcontroller, that accepts commands at TTL levels running at 9600,8,N,1. I am getting the signals to the DMC-8, but no luck yet. Is it possible to emulate an UART over an expander? If so, any help would be greatly appreciated. Also, should I being sending LSB or MSB first?
Joe
Joe
Jon Williams
Dallas, TX· USA
This is not easy, but the Javelin can do it. However, if you now try to get an I/O expander output pin to toggle that fast -- well, you need to send into the I/O expander at least 8 times faster, right? I don't think the I2C bus can run that fast.
That's the basics of your problem in a nutshell. You MUST connect the DMC-8 directly to a Javelin pin for this to work.
PS Has anyone worked with a BL233 chip?
Joe
Yes, you are correct about the I2C and I am currently using it. I am sorry I did not explain why I was doing this. I wanted to extend the I2C bus to over 300 feet and keep my cable count down to my remote unit to one cable. But this plan was getting crazy, so I have decided to go with 3 cables and forget extending the I2C bus. I plan on using a protocol that is built for the distance. I plan on going from RS232 to RS 422/485 and back to RS232 and where needed, to I2C.
Joe
