RemoteControl and Javalin
I’m trying to remote control my robot using a Futaba receiver, a Javelin and a dual H-Bridge. I would like to ask you :
Thank you all.
|·······Futaba Receiver··· |
· Servo1·|······· |Servo2····································
| JAVELIN························· |
en1 A+ A-······ en2· B+ B-
| Dual H-Bridge················ |
- Which is the best way to read the output of my receiver? (pulseIn or is there any other Object to do this task as a VP?) If I use this pulseIn method can I use the timer to make it run as a VP?
- The second question is for the output from Javelin. To control the H-Bridge is it good to use the “CPU.writePin(CPU.pin1,false)” inside a Timer object or is there another better way?
Thank you all.
