Stamp architecture
Are ALL Stamps TTL compatible?· No CMOS inouts or outputs?
Sid Weaver
Do you have a Stamp Tester?
Sid Weaver
bugg
I think I know what I'm doing...
Sid Weaver
bugg
Please correct me if I'm wrong.
The only potential problem that I see is that the TTL logic levels in the stamp define anything above 1.6 vdc as a true. This gives you only 1.4vdc max of headroom between a true and false condition. Too much voltage drop or noise in the circuit could cause an incorrect reading.
Jim
Sid Weaver
