driving a linear positioning table
I have an 8 inch linear positioning table from NEAT (New England Affiliated Technologies) and have some questions on driving this thing via a BS2. Basically, this thing is just a stepper motor with a leadscrew attached to the shaft with a table that has a threaded section so that it moves along the rail as the leadscrew turns. Well I have 2 questions. Firstly, I am not 100% sure of the voltage ratings on the stepper, but I am assumimg it's 12v because it wouldn't do much more than quiver when I ran it off 9v. Is this a safe assumption? Secondly, I have the BS2 running the stepper (it's unipolar BTW) through a ULN2003. Well I have 2 problems with this. The ULN2003 is only rated for up to 500mA. The only 12v power supplies I have supply 4-6A. Thats not good, because I burnt one out (ULN2003), meaning the stepper draws more than 500mA. But I am not quite sure how much curent the stepper in the table draws, and if 500mA would be enough for it. Anyway, what would be the appropriate sized resistor to turn it down to 500mA max, and if it's not enough, what would you suggest instead of a ULN2003?
Thank you,
Justin Woodman
Thank you,
Justin Woodman
kelvin
Justin
kelvin
