Interfacing Digital Devices
I have a digital temperature module (FE33) which I want to interface to my BS2.
The FE33 has an AA battery powering it. The BS2 is on a BOE.
The FE33 has a digital output pin. How do I connect these two devices together so that I can use SERIN to read the FE33's value?
I have used SEROUT before to control a PAK-V, however the PAK-V did not use a separate power supply from the BS2 so I understood the circuit.
It may be possible to power the FE33 from the BS2's VDD if this is necessary however I have had problems with this.
All advice would be very much appreciated.
Many Thanks
Andrew
Many Thanks
Andrew
Jon Williams
Dallas, TX· USA
How should I have set up the circuit for a common ground?
Andrew
What is the output from the FE33? Do you have a link to tech docs?
Jon Williams
Dallas, TX· USA
I have another problem now though - the 1.5v High signal from the FE33 is not enough to register as High on the BS2 because it is less than 2.5v. I have tried using a transistor to amplify this signal - but because of the diode effect of the transistor is is impossible for the BS2 to read a Low value.
Can I make a circuit that will amplify the signal using a transistor, or will I have to buy some opto-couplers?
Andrew
Thanks for your suggestions and advice.
Andrew
