PWMPAL help
I have tried everything I can think of to get this PWMpal to work with my BS2p24 and it just won't respond. I send it the following program:
SEROUT 0, 6, [noparse][[/noparse]"!PMWGS"]
SERIN 0, 6, [noparse][[/noparse]status]
DEBUG status
and it never gets past the SERIN. Should I be setting all the pins to input mode before this? Does anyone have any clues not mentioned in the manual? I searched this forum and on google and I couldn't find any new ideas.
Thanks for your help.
-DAvid
DEBUG status
-DAvid
Better yet, add this to the top of your programs that require serial routines:
#SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 TMidi CON 12 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 TMidi CON 60 T38K4 CON 45 #ENDSELECT SevenBit CON $2000 Inverted CON $4000 Open CON $8000 Baud CON T38K4Then your code becomes...
... and will work with any BS2 module.
Jon Williams
Dallas, TX· USA
I have to go try that right now! I just wish I had keys to the lab.
I'll post back my progress later.
Thanks again.
-David
Jon Williams
Dallas, TX· USA
