7805 substitute — Parallax Forums
7805 substitute
Robert SchwartzRobert Schwartz Posts: 141
edited 2005-02-26 02:11 in General Discussion
Hey guys. I was wondering if there is a good substitute for the 7805 regulator. I know about the LM2937, but not much. Is it pin for pin compatable with the7805? Is it better/more efficient? Thanks.
  • kb2hapkb2hap Posts: 218
    edited 2005-02-08 03:45
    could you be more specific.· what are you looking for exactly?· more amps, better efficiency, different package?
    you make want to just take a look at the various suppliers
    www.mouser.com
    www.jameco.com
    www.digikey.com
    www.newark.com
    thats just to name a few...most of then also supply data sheets which can give you information on pin compatability and how to use/interface them.
    DTQ
  • Robert SchwartzRobert Schwartz Posts: 141
    edited 2005-02-09 00:00
    Thanks kb. Has anyone heard of or used the Microchip TC1262?
    edited 2005-02-09 00:02
    I am looking mostly for a lower dropout and more effieciency.
  • BeanBean Posts: 8,129
    edited 2005-02-09 02:27
    For 150mA or less check out the TL750L05CLP from TI.
    It is a TO92 package with a dropout of 0.2V @ 10ma and a max loss of 0.6V at 150mA
    Plus it's cheap. Only $0.68 for 1 pcs from digikey.
    Bean.
    Post Edited (Bean) : 2/9/2005 2:30:12 AM GMT
    edited 2005-02-09 03:47
    Thanks bean, but I'm going to need at least 300-400 ma.
  • Mark GMark G Posts: 11
    edited 2005-02-09 17:45
    Scott Edwards Electronic site has a good schematic for a 5VDC power supply which uses either a 7805 OR 78ST105HC.
    http://www.seetron.com/an_vpwr1.htm
    I have built the 78ST105 version and have been very happy with its performance...
  • Jim G.Jim G. Posts: 27
    edited 2005-02-09 21:27
    I am currently working on a project that has a 24VAC power source that I·am using for my 5VDC supply.· This heats up a 7805 even at low currents.
    To be more "green", and also to experiment a little, I have been looking at a buck-type switching regulator, LM2574-5 from Micrel, http://www.micrel.com/.· I have avoided these circuits in the past because they seemed too complicated, but it's not so bad these days; they only use 4 external components.
    I haven't actually fired one of these up yet, but I plan to try it out.· It will be more expensive to use this type of regulator, around $4(?) for it and all the external parts, but it is worth checking out.
    Jim
  • MacGeek117MacGeek117 Posts: 747
    edited 2005-02-09 22:03
    Or you can check out Karl Lunt's book BUILD YOUR OWN ROBOT! and look for the
    JBS (Junk Box Switcher).
    bugg
    So many projects, so little time.
    edited 2005-02-10 01:07
    Thanks guys. I think I found what I needed though, the MAX603. I ordered a few so I'll see how well the work. Mark, that power supply liked pretty nice for getting higher voltages down to 5. I'm probably going to be using that in a different part of my project. Jim, those regulators do look nice, but they are pretty expensive, and I don't feel like ordering them in 50pc rails. Thanks though.
    Robert
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2005-02-25 22:43
    Here are a few low dropout regulators that have just been released...
    Low-Quiescent CMOS Regulators - February 23, 2005 News Release
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
    Wow, only 1uA shutdown draw, and 100uA max draw. Thanks Beau, those are pretty much exactly what I was looking for.
