servo control question
Hi all!
I have a servo for a nitro model, that's not modified, and has the following specs:
Signal pulse: Positive Pulse Control 1520us Neutral
.14sec 0-60 deg.
Can anyone help me to control it with a BS2sx or p24?
And I need some info how to monitor a controller reciever for it?
Thanks for the anwser!
.14sec 0-60 deg.
' The BS2sx uses something else -- 800 uSec?
' This example uses BS2 numbers -- adjust the 'count' values
' for the BS2sx.
'1. Holding at neutral...
LOW ServoPin ' Set servo pin as Output, and LOW. Servo control uses positive pulse.
MAIN:
PULSOUT ServoPin, 760 ' 2 uS per 'count' in BS2, so 760 == 1520 uSec
PAUSE 20 ' Pause 20 mSec -- Servo's work on a pulse, then get refreshed every 20 to 50 mSec
GOTO MAIN
' 2. Typically, 1 mSec is full left, 2 mSec is full right.
' So, full left:
MAIN:
PULSOUT ServoPin, 500 ' 500 * 2uS == 1,000 uS, or 1 mSec
PAUSE 20
GOTO MAIN
AND -- the Servo power ground and the BS2 ground MUST be connected.
The servo specs? From it's desc.
