IF...ELSEIF problem
I am currently working on a robotics project and I need to use an if elseif statement. The segemnt of code I am using is:
IF (Close_Right = 1) THEN CloseRight
ELSEIF (Close_Left = 1) THEN CloseLeft
ELSEIF (Far_Right = 1) THEN FarRight
ELSEIF (Far_Left = 1) THEN FarLeft
ELSE GiveUp
ENDIF
All of the variables are initialized and all of the labels have contents, but I get the error, "'ELSEIF' must be preceded by 'IF'" whenever I try to tokenize it. What is the matter with my syntax? Thank You.
ELSE GiveUp
ENDIF
It doesn't take much more typing, and it does make the structure easier to read.
Jon Williams
Dallas, TX· USA
It would appear as though this style is now enforced by the parser
IF (CloseRight=1) THEN CloseRight
is a 'single line version' of the IF statement -- the statement ends with the line-feed.
Thus:
IF (xyz) THEN GoToTarget
ELSEIF (abc) THEN GoToAnotherTarget
' The ELSEIF actually has no 'IF' in front of it,
' since the single-line IF is already done.
The equivalent for your code is:
GOTO GiveUp
Thus you don't need the ELSEIF construct -- it's already built into the code flow.
