Thanks for the info.· I have the clips for single LEDs, but I'm not sure how to mount a 7 segment display.· I also thought that there might be a smooth plate or cover to hide the screws (for looks only)
Suggestion on the 7 segment is get a thin piece of acylic or lexan and glue it to the underside of the opening (tinted the color of your LED segment if you want) There are a bunch of sites online for people who mod thier PC cases that sell the stuff.
You may be able to find a bezel the size of your opening, or you can get some aluminum stock with the same finish as your enclosure, use flush screws and glue your homemade bezel. It would prevent you from removing the screw, but you could still remove the part by unscrewing the bolt on the underside. Many manufacturers of electonic devices don't even bother though. I repaired a friend's $3000 mixing console and they just used flush screws that were anodized the same color as the enclosure.
Post Edited (Paul Baker) : 2/4/2005 6:45:24 PM GMT
I often mount the board that the LED/LCDs are mounted to, right to the front bezel.· Depending on the screws used, it can be very clean.· Also some enclosures have slots for PCBs that cab also be used as a clever way of hiding this.· For example, you could cut a plastic baffle and mount the PCB to that about 1/8"-1/2" from the front bezel (Depending on what you display height is) and then just cut out the display area from the front bezel.
Thanks for the suggestions.· They DID make perfect sense.· I was·hoping to find some super-clean solution to hide the poor cuts I make in the enclosure, but I guess I'll just have to more careful.
I'm with Nightrider, I can't cut neat openings either, so this thread intrigues me. Out of curiousity I searched around on DigiKey. There are bezels available for LCD and LED displays. Search on "bezel" then look under Optoelectronics. I don't know what size of display you are using, but these might be of some help.
dunno if that is a cookie enabled link or not, if it is, goto·www.radioshack.com >Parts, Tools & Wire > LEDs > LED Holders & Assemblies.
Paul
Hope that made sense.
--==<{Chris}>==--
Jim
