How to control 110v AC
I want to control 3 110v devices (with individual standard outlets, a la X10) with LCD and timer, but I don't want to use X10. From previous posts I have learned that a triacs/solid state relays would do the job. The 3 outlets would drive 3 60W power compact lights with ballast and standard plug. Basically, I am looking to integrate 3 standard 110v outlets in one box and control it with a stamp.
Does anyone have any recommendations?
Thank you very much in advance.
Others have used Tri-acs in this instance, I'm sure.
bugg
So many projects, so little time.
Thanks a lot..
Post Edited (Monoment) : 2/4/2005 7:43:40 PM GMT
You would have to have 3 of the 'appliance' modules, probably plugged in to a power strip. One module could be the RF reciever for the 'Firecracker' sending unit.
There's no way to implement X10 controls on your own PCB, but having three appliance modules is hopefully not too great a burden.
Check out www.x10.com for the Firecracker kit. People do have the protocol for the CM11, and CM17 (one of which is the firecracker unit)
Any other suggestions?
Post Edited (Monoment) : 2/4/2005 9:10:34 PM GMT
http://www.jameco.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10001&catalogId=10001&langId=-1&categoryId=11582
DTQ
