Underwater Fish Tank LED Lighting
Looking to run some LEDs in a freshwater fish tank, driven by a Stamp to control lighting effects and timing.
The main electronics will be well away from the water, safely positioned with 3' wires running to the different LED units. Most of these will be on the hood of the aquarium, but I would like to submerge some also.
I will fully insulate the LEDs with RTV silicon and the project will be driven by a 12DC wall adapter.
If I were to have a failure in one of the leads carrying current to a submerged LED - what dangers are there to humans who may touch the water and to the fish in the tank? I will have a GFI receptacle, but think that it might be unnecessary based on having a 12 wall adapter that is basically an isolation transformer.
What thoughts do people have on this?
For the fish there is no path to ground anyway, they are in a glass aquarium. It's the "bird on a wire" analogy.
For someone reaching into the tank, they create a path to ground through their feet or any part of the body touching earth. But again, as long as all is low volt/current there is no chance for danger.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Also, if you have a bubbler...I don't know if there's any metal bits that create a path back to a motor...who's case is probably a ground point....so your bubbler might quit if there's a short.· I'd say you'd lose your wal-wart first though!
Anyone watch Fear Factor the other night....you could film your fish tank and watch people doing the same stunt!
Steve
http://members.rogers.com/steve.brady
If insulation on your submerged LEDs fails, there is still going to be enough resistance in the water to prevent a total short, but you might start electrolysis. Signs: bubles rizing from the submerged contacts. Depending on what is added to the aquarium water, electrolysis of that solution, can produce a number of different chemicals (also depending on material of the wires). I bet your fish are not going to like that.
Since the LED's work on low voltage, i would not see a problem, just seal them up good.
Post Edited (Paul Baker) : 2/4/2005 11:43:54 PM GMT
just my opinion.
DTQ
Shawn
Shawn Lowe
Remember - No matter where you go
There you are.
wiring waterproofed/protected. Also the True Value/Ace hardware store in town carries it as well, but not in as many diameters.
Good luck!
Bob
Bob
·· We had recently watched a show on TV that I think explains why sharks are affected by even minute quantities of electricity...Apparently, they can sense the electrical pulses given off by other fish/mammals when they move their muscles.· Apparently they are very sensitive to this, and so I can understand what you're saying.· Interesting stuff...
--==<{Chris}>==--
