Comp no longer detects BS2
I need help...
My computer no longer detects my BS2. I'm hoping i didn't damage something.·I had a simple·program - basically wanted to set up a switch. Set P15 as input. When switch is off VDD goes to ground. when switch is closed, VDD goes to P15.
Can someone help?
Thanks·
Can someone help?
Thanks·
What is the exact message you are getting?
What kind of computer are you using?
Are you using a serial port or a USB port to connect withthe Stamp?
WinXP
serial port
it was working fine right before this... the program ran fine as well...
i'm worried i might have damaged the board as i did not have a load resistance inbetween VDD and P15... is that needed?
Vince
Think i'll need to send it in for repair. Support said it would cost $28. Considering that plus the cost of shipping both ways, i think it might be cheaper to buy a new module...
