RS232 adaptor for debugging...
I am getting ready to create a little project and want to make sure I can't
just buy the thing before I make it.
In most of my SX projects I try to reserve port·A for diagnostic serial I/O, but I don't
want to put a MAX232 chip permenantly on the board.· So my idea is to
put a 6 pin header·on·the main·board with +5, Gnd, and RA.0 - RA.3,
sort of like how the SX-Key connects.
Then I want to plug·an interface board, a lot like the SX-Key, on to that
6 pin header, and connect it to my PC terminal program.· The only thing on
this little board is a DB-9S, MAX232, and a 6 pin female header.· Like I said,
this is really like the SX-Key, but with an RS-232 chip, and nothing else.
Depending on the application, one could output run-time status messages
out this port, but normally nothing is connected.· Plug on this little board
and easily watch the messages fly by...
Any comments about this will be appreciated,
Jim G.
Jim G.
PCs also will usually accept TTL into the serial input.
James Newton, Host of SXList.com
james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
I also like David's idea about using an LCD module, and will look in to that as well.
Thanks all,
Jim G.
http://www.sxlist.com/techref/io/serial/ttl-rs232.htm for some very useful "cheats" which will work most of the time.
I leave the MAX232 chips off and just keep the RLC1's around for the few cases where they are really needed.
