Interfacing The TLC5615 DAC
hello..
Im interfacing TI's TLC5615 DAC to the BS2 .Its a 10 bit DAC ..
According to the datasheet i have to clock in 10 bits plus two dummy bits .That makes 12 bits
So my SHIFTOUT command is as follows
SHIFTOUT dac_DIN,dac_SCLK,1,[noparse][[/noparse]i/12]
where
dac_DIN...input data line
dac_SCLK..clock line
1...MSB first
i ...my dac data ranging from 1 to 1023
My reference is at 2 volts
My qusetion is..
How do i append the 2 dummy bits to my DAC data?
See page 8 and 9 of the TLC5615 datasheet
http://www-s.ti.com/sc/ds/tlc5615.pdf
Thanks in advance
**·ice**
Gerard Sequeira
Machinegrid.com·:: Robots at Work!!
Parallel Port Tutorials,
Autonomous Robots,
PIC16F84a Temperature Controller
where
1...MSB first
My qusetion is..
Thanks in advance
**·ice**
Gerard Sequeira
Autonomous Robots,
This stream sends four dummy bits (1s), the DAC value, the pads with two zeros.· Note that the bits parameter uses the back-slash ( \ ) and not the division ( / ) operator.
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 2/2/2005 2:23:32 PM GMT
That worked like a dream...
No problems at all....
**·ice**
Gerard Sequeira
Autonomous Robots,
