Need help with transmitting data by IR
I am working on a project were I need to transmit serial data by IR.· In other words I need to do what a TV remote does.· The data I need to send will be constantly changing based on user input.· I have tried to solve the problem myself, but being new have been unable to find the information I need and was hoping the forum community could help.· I have searched the following resources and found them only teaching about how to read data by IR from a·remote NOT how to generate it.
Resource consulted:
Thought maybe an IC was used to generate IR pulses based on serial data sent it.· Looked in Mousser and Jameco catalogs and found nothing.
Any help would be most appreciated.
Tony
Resource consulted:
- What’s a Microcontroller.
- Robotics with the Boe-Bot
- IR Remote Boe-Bot
Tony
Jon Williams
Dallas, TX· USA
I still have the code if you would like me to email it to you.
mail_for_music@yahoo.com
Bean.
I want to transmit serial data to another device using IR. The data will not be data files, but information about switches - 0n/off and a linear pot's postion and if it has moved to a new postion. The second device will recive IR data from control device and control servo postion and turn circuits on/off. I can as musictech said store switch ids and state codes in memory. Still working on how to implement the pot's position data
My question restated differently is this:
How do I pulse an IR LED to send data like - 00001011 pause 00000011? Which when recieved by the second device it would read data as - switch 0ne - on - then turn lights on.
Thanks for the help
Tony
http://www.parallax.com/dl/docs/prod/audiovis/InfraredEmittingDiode.pdf
The code is a little old.· Assuming you are using a BASIC Stamp 2, make sure to add this directive to both example programs:
' {$STAMP BS2}
Post Edited (Andy Lindsay (Parallax)) : 2/3/2005 3:36:45 AM GMT
http://www.parallax.com/detail.asp?product_id=28016
--==<{Chris}>==--
