Explanation of retiw please
Hello guys,
I'm trying to figure out how to correctly set the offset for retiw. I've read the manual, beg program guide, and searched this site and sxlist and can't quite figure out how to correctly do so.
I am designing a frequency counter (for frequencies <500Hz). The program counts inbetween clock pulses, and when a new pulse comes in, it updates the display. Here's some sample code:
Can anyone explain how the offset for retiw should be set in this example?
David
Post Edited (Catware) : 2/1/2005 4:01:22 PM GMT
org 0 ; code start isr inc counter snz inc counter+1 mov !rb,#%00000000 ;read pending and clear mov edges,w jnb edges.0,:return ;no incoming edge->return setb settings.0 ; clock pulse came in mov lastcounter+1,counter+1 mov lastcounter,counter clr counter clr counter+1 :return mov w,#-256 ;interrupt every 20.48 uS (1000 instructions * 20ns per instruc / 4 prescaler) retiw start_point [noparse][[/noparse]clear all variables] mov !option,#%00000001 ;set RTCC to internal clock 1:4 ratio (20.48us) mode $0D ;Logic Level Mode mov !rb,#%00000001 ;one pin TTL mode $0E ; pull up resistors mov !rb,#%00000000 ; 8 pull ups mode $0A ;Edge Detection mov !rb,#%00000000 ;rising edge mode $0F ;Direction Mode mov !rb,#%11111111 ; 8 inputs mov rb,#00 ;clear mode $09 ;Enable Pending Register main jnb settings.0,:no_pulse [noparse][[/noparse]compute 1/lastcounter * calibration to obtain Hz] clrb settings.0 :no_pulse call multiplexLEDs jmp main
David
If so, the slowest interrupt period you can have is 50000000/256(prescaler)/256(rtcc overflow) = 762.939453125 or 1.31072 milliseconds.
Bean.
Post Edited (Bean) : 2/1/2005 7:48:57 PM GMT
I am using a 50Mhz clock, and do know how to set the prescaler. If I'm okay with interrupts occuring at the rtcc rollover rate (20.48us with 1:4 prescaler), then I don't need to mess with retiw? But if I wanted interrupts at 20.00us then I would set the retiw at #-250?
Hmmm, maybe that's the answer. I thought retiw was supposed to compensate for varying code execution times in the isr routine, but is its use only if you want different interrupt times than what the prescaler can give you?
p.s. it's 1.31ms, not 1.31usec· ·
If you want 256 you don't need retiw because RTCC keeps updating while in the interrupt routine, so the interrupt routines time is taken into account.
Bean.
