Clock output pin for synchronizing external electronic devices
Hi
I have a problem. Anyone can help?
Does Basic Stamp 2 controller have a clock pin, for clock synchronization with external devices. For example a Analog-Digital converter and any digital electronics device that require a clock input from the control.
Thanks.
Thanks.
Take a look at the SHIFTIN amd SHIFTOUT commands in the PBASIC Stamp Manual, or the help file. You have your choice of which pins you chose to use as a clock and data pins. There is no one single pin designated as a clock pin to directly answer your question.
Other Stamp platforms also use I2CIN and I2COUT which you may want to take a look at as well. In this case there are specific pins which must be used. These commands are not available on the plain BS-2 however. The BS-2P and BS-2PE do support these commands.
Bruce Bates
