bluetooth
good morning
is it possible to connect the module to stamp bs2 ?
tank you
http://www.air2u.com.tw/products/bcr.htm
Post Edited (prisco) : 1/31/2005 10:02:08 AM GMT
tank you
Looking at the website and the datasheet I would say: maybe it can be done but you may need a level shifter (ie MAX 232).
But you will have to try it to know for sure. If they are not too expensive I would have a go
Klaus
I HAVE BEEN USING ANOTHER THAT PROVIDES BOTH ENDS...
http://www.aircable.net/AIRcable/CLI.html
THINK I PAID ABOUT USD 128 INC 2 ADAPTERS AND 2 WALL WARTS.
ON REAL RS-232 THEY WORK GREAT.
LIKE KLAUS SAID. FOR THESE TO YOU WOULD HAVE TO USE TTL TO RS-232 LEVEL SHIFTING. AL WILLIAMS (AWC) PUTS OUT A KIT THAT WILL WORK WITH THEM.
http://www.awce.com/rs1.htm
I AM "CURRENTLY" USING MINE BETWEEN 2 COMPUTERS WITH PC ANYWERE 4.5..... ALSO USE THEM BETWEEN A LAPTOP AND A AMATEUR RADIO PACKET TERMINAL NODE CONTROLLER WHICH IS SET UP IN THE GREENHOUSE. HAD TROUBLES WITH MICE EATING CABLES GOING INTO THE GREENHOUSE. NO MORE.....
73
SPENCE
K4KEP
