Optascope Activity #1
The text for activity #1 says to set the Trigger Source to "None".· This isn't an option; only Channel 1, Channel 2, and External.
It also says "drag the arrow to the left of the Plot Area to set the trigger voltage."· I assume it meant to say "to the right"?
Figure 1-17 shows the Horizontal set to 200us instead of the expected 5ms and the Trigger Settings box in the upper right is set to "CH2".· Is this correct?
You are also correct, the trigger voltage is set on the right side of the screen.
With Figure 17, again the settings could be what you suggest (and would be more clear to someone just starting out) but I think the point of the exercise is to observe the +5 V signal, which looks the same regardless of these settings.
nate
-Mike
