Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
sensing 120vac — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
sensing 120vac
jrcowboy
1
2005-01-27 20:48
edited 2005-02-10 13:33
in
BASIC Stamp
whats the best (and most robust) hardware solution to input a 120-240VAC signal to the stamp?
joel
Jon Williams
6,491
2005-01-27 20:50
edited 2005-01-27 20:50
Use an opto-isolator. Opto-22 makes a module that will let you put 120 VAC in and get a TTL level out.
Jon Williams
Dallas, TX
USA
Pinoy NYC
30
2005-02-10 05:13
edited 2005-02-10 05:13
Jon,
what will be the output in voltage of the OPTo-22 if you feed a 120VAC?
will that be around 5VDC?
Thanks.
Jon Williams
6,491
2005-02-10 13:33
OPTO-22 makes modules that are TTL compatible. I believe they have a pull-up on the output pin which would put the output at five-volts with no AC present; when the signal arrives the output line is pulled low.
http://www.opto22.com/asset/documents/0251_G4_Digital_AC_Inputs_data_sheet.pdf
Jon Williams
Dallas, TX
USA
Sign In
Register
to comment.
Jon Williams
Dallas, TX· USA
Thanks.
Jon Williams
Dallas, TX· USA
