Need help--how can I use BS2 to control Kitsrus K108 I/O module......SEROUT?
Hello-
I have an 8-relay serial I/O controller board I would like to use in a project (Kitsrus Model K108). This unit was designed to run off a PC via the serial port, and control the relays via simple text commands (ie "N1" for relay 1 on, "F1" for relay 1 off, and so on). It is not stand-alone programmable.
I recently began working with the BS2, and would like to use it, as an embedded controller hooked up to the K108 I/O board in a project to control a series of 100W floodlights.
I have been trying to use the SEROUT command, with a straight through cable connected from the BOE 9-pin, to the 9-pin on the K108. I set the parameter in my BS2 program to output to 'pin 16'--the serial port--and entered the number for the proper baud rate, etc, and put N1, CR in brackets (the K108 docs says a CR must be received before the command is executed), PAUSE 500, and then F1, CR.
My program loaded successfully into the BS2, and when its running still hooked to my laptop, I can see the light on my USB-to-Serial adaptor, flashing.....so I know the BS2 is putting the output out it's port.....but when I hook the BS2 to my K108, nothing--no relay activity, no Data LED flashing on it, at all.
Has anyone out there, used this I/O unit with the BS2 before? Basically, it's just a ULN2803 Darlington array, hooked to the relays, and controlled by a pre-programmed AT89C2051 microcontroller (reading numbers off the ICs). It's just a nicely-built module, I'd really like to use since I have it.
Any ideas or help would be GREATLY appreciated. My project is due Feb. 10th. [noparse]:)[/noparse] Thanks!
Using this template you should have a Baud definition like this:
If I'm wrong and you need inverted mode, change the definition to this:
Jon Williams
Dallas, TX· USA
Jon Williams
Dallas, TX· USA
Sorry ChrisO... hope you share a project "how-to" with us...
