No More Redi Web Server?!
All -
I just received news from Jim in sales that there will be no more redi web servers produced. Apparently, the company has chosen not to make them anymore and will not be honoring any backorders.
Speaking as someone who found the device to be extremely useful (I had 11 on backorder and was ready to order another 30-40), I am not sure what my options are now. I'm sure that the engineering department at Parallax is considering alternatives, but, of course, I was just about to kick off a project that used them and I am left wondering what I am going to do.
So, a couple questions:
Does Parallax have any plans to replace the redi, or take it over and continue producing it?
If Parallax is going to replace the unit with something else, is there even a timetable for the replacement becoming available?
Is there a person at redi that I could contact that I could plead with to receive some?
Is there a viable alternative out there?
If anyone from Parallax is reading this, please let me know what you think. I have to choose a new direction and I'm disturbed that this could just come out of the blue like this. From what I hear, Parallax did not have any say in the parting of ways, and I don't blame you for the problem. I'm just wondering if there's any alternatives out there.
Chris
Chris
Jon Williams
Dallas, TX· USA
match the red-i but they do offer DIL modules as well as
standalone products.
http://www.sena.com/products/by_name/hd_lite/
regards peter
Thank you both for your input. I checked out your collective recommendations, and I have ordered a couple of the site players to test. It offers some neat features that I hope Parallax will consider when they come up with an alternative to the redi.
Again, thank you very much. I was very disappointed last night, but now I see a light, and it's possibly better than the previous solution.
Chris
We were also very dissapointed about the Red-I supply situation. It was a situation we have experienced with smaller suppliers in the past. Just because a company can produce a good product doesn't mean they can actually supply it. In this case we didn't have any viable alternatives, so we decided to discontinue the product and cancel customer backorders before the situation got any worse.
I also really liked the Red-I design and was looking into using it for web control of my Marklin 1-gauge train.
We didn't want to violate our customer's confidence in Parallax any further.
As for alternatives, we don't presently have anything in process but we're looking into different options. Check out the Sena device in the meantime. Or, if you only need Stamp e-mail, we've got the new Cermetek E-mail Modem in production (very similar product to our StampModem in design). We're about a month away from availability on that product.
I know it sound very "un-detailed" but I can't get the idea from their website
what I can expect by using this thing compared to the red-i webserver.
Thanks, Wim
Check the manual out @ http://www.siteplayer.com/docs/001212/SitePlayer_Software_Manual.pdf
There is some code on the siteplayer forums for the bs2 also.
On the BS side, you can serout/serin data to the SP.
Temp = 70
SEROUT SP_RX,Baud,[noparse][[/noparse]$81,Adr,Temp.LOWBYTE,Temp.HIGHBYTE]
The siteplayer will take this and use it to create the web pages.
The current temp is ^temp F
Will become
The current temp is 70 F
You can send data to the siteplayer like
http://www.xxx.yyy.zzz/tstat.spi?setpoint=75
Then read it into a BS via serin
You have 768 bytes of ram that can hold your data, and 48K for your static html and graphics.
8 I/O that can be set via www, rs232 also I think?
UDP send/receive
It will NOT send email directly
It can interface with some spi ICs directly
It has a status byte which can be checked to see if a page has changed, this also can be a I/O pin
New pages can be downloaded to it via ethernet
I use the wiring diagram @
http://www.siteplayer.com/docs/001212/SitePlayer_Devel_Board_schem_2003.gif
for the ethernet interface, with magnetics from www.pca.com - part # EPJ9372 $3.33/ea
You can see it here:
members.cox.net/dc13_tcp_ip/siteplayerjackcombo.jpg
Simple connection setup. All the pins on the right side of the SitePlayer are open for what ever you want to use them for. To interface with a Stamp at this point is trivial.
I have extras, let me know if you are interested (happy to let you have them at cost)-
Ryan
Post Edited (LostboY) : 5/5/2005 5:09:36 PM GMT
You can use UDP also.
Ryan
How much and how?
Ryan
http://www.parallax.com/detail.asp?product_id=30013
with an almost identical software interface regarding stamps.
So I updated my Red-I class into a Pink class for this new module.
http://groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/peripheral/web/
This new module has·all variables 64bytes wide, which
makes the code even simpler.
regards peter
