help: flex sensor interface to basic stamp BS2p40
I am working on a project that uses flex sensors(variable resistors...max resistance when flexed..·minimum resistance when un-flexed)·attached to each finger of one hand·to trigger the SP03 speech module to say one of its phrases.· For example...lets say I have two fingers flexed and 3 that are not....the basic stamp BS2p40 will read these states and trigger one of the pre-defined phrases the SP03 has stored.· So basically I want the stamp to read either a flexed or un-flexed state of the flex sensors.· Does anyone have an·example...hardware and software...that will allow the basic stamp BS2p40 accomplish reading in these states?
thanks.....chris·
thanks.....chris·
use the circuit on page 195.
bugg
So many projects, so little time.
