Radio conrol?
Hey! I was wonderin if it was at all to retrofit a 72 mhz radio controller to control the boe bot? It is just a plain old futaba 4 channel radio. Is THis at all possible?
Thnks!
![jumpin.gif](http://forums.parallax.com/images/smilies/jumpin.gif)
![hop.gif](http://forums.parallax.com/images/smilies/hop.gif)
A CHAIN IS ONLY AS STRONG AS ITS WEAKEST LINK
GENIUS IS 1% INSPIRATION AND 99% PERSPIRATION
THERE IS ALWAYS GOING TO BE ONE PERSON RICHER THAN YOU, UNLESS YOUR NAME IS BILL GATES
What is is, what is not is not, isn't it?
It is.
Thnks!
It is.
72 mhz is for aircraft, helicopters blimps and the like which are airborn.
It is not legal to modify it yourself uness you have a fcc general commercial radio license.
75 mhs is the only band for unlicensed operation for ground or water..
73
spence
k4kep
And, as Spence says, you don't do this by hacking the RC reciever, merely by using what the R/C reciever already gives you.
RECEIVER SERVO TO A MICRO OR DIRECT SAY TO A MC-7 MOTOR CONTROLLER
USED BY KADTRONICS ON THE WORKMAN II OR III.
QUOTE FROM MC-7 MOTOR CONTROLLER BY "DIVERSIFIED"
Control it from your microprocessor by applying a PWM control signal between the
"pot wiper" (PW) terminal and ground to control speed, and a +5V signal on either
the forward or reverse connectors to control direction. Enable it with +5V on the
enable terminal. END QUOTE
I THINK THEY ARE SAYING THE PCM RECEIVER OUT PUT IS THE SAME AS PWM.
COMMENTS?????
YOU HAVE TO USE SEPERATE MOTOR CONTROLLERS FOR LEFT AND RIGHT SIDE.
BTW I AM TRYING TO DECIDE BETWEEN THE KADTRONICS OR A 16" SQUARE
ZAGROS.
https://www.zagrosrobotics.com/shop/item.asp?itemid=517&catid=1
AND THE KADTRONICS 4 WHEELER
73
SPENCE
K4KEP
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
Designs Page:··· http://www.lightlink.com/dream/designs
It is.
The quote you presented sounds as if there is an interface so a Microprocessor generated PWM signal could interface with the MC-7 drive electronics -- but PWM is NOT a 'Servo Control Signal', and is MUCH harder to generate with a BS2. I don't think the two signals are the same.
But true, some do still use modern components with old methods, so you might find crystals.· But they may not work with all the filters that are in the radio.· Especially today with the 'bands' being so congested, there's a push for manufacturers to keep things tighter so they don't interfere with their 'neighbors'.
We had a radio transmitter who's filter had let out the smoke, but the radio kept chugging along.· But instead of transmitting at 164Mhz with whatever bandwidth, we were on every multiple of 800kHz above and below our frequency.· Just so happens we were interfereing with the railways radio comm lines (emergency lines?).· Well, they promptly kicked in the door to our shack (remote area, nobody to call) and shut off our gear and called Industry Canada.
If you go about modifying radio gear that's near aircraft bands or other 'priority' bands, then you need to know if you are 'bleeding across' the band.· A Spectrum Analyzer is nice for this....but if you can afford one of these, then you can afford to have a company custom build you a transmitter or 100!
Steve
http://members.rogers.com/steve.brady
It is.
ps i know basically nothing about remote controlls but i found this intersting
It's true that you can connect the receiver outputs directly to the Boe-Bot's servos, but in doing so, you would loose the ability to programmatically fine tune the handling, check sensors and override the remote control, and other cool projects.
I think it would be way better to have the BASIC Stamp measure the pulses the receiver sends and use those measurements to control its servos. Make sure the receiver's ground is connected to the Boe-Bot's ground (Vss). Then, the connections on the receiver that used to send the pulses to the plane/boat/car's servos can send pulses to BASIC Stamp I/O pins instead. The BASIC Stamp can monitor these signals with the PULSIN commands, then control its servos (connected to different I/O pins) with the PULSOUT commands.
If you don't have the receiver any more, one option would be to take your radio control down to a hobby shop and see if they can set you up with a compatible one.· Given the choice between that and blink13's link, I'd definately opt for blink13's link.·
As an aside, here's a link to an article with an RF controller that you tilt to control the Boe-Bot: A Tilt Radio Controller for Your Boe-Bot
Post Edited (Andy Lindsay (Parallax)) : 1/28/2005 1:29:26 AM GMT
What I tried to get the Stamp to read the RC pulses with PULSIN and PULSOUT commands and also check sensors for objects, the servos did not run smoothly. While the program was checking the sensors, no signal pulses are being sent to to servos. To get around this I used two SPDT relays to switch control between the RC and the Basic Stamp program that checked for objects. Nornally the RC receiver controls the robot drive wheel servos directly. The Basic Stamp program runs all the time checking the sensors for objects. The relay coil is controled (thru a transistor) by toggling pin 6 from low to high. If no object is detected pin 6 is LOW and the relay allows RC control. If an object is detected pin 6 goes HIGH and relays switch the servos control to the Basic Stamp navigation routines. When the object is no longer detected pin 6 is toggled back to LOW and the RC takes back control.
This seems to give nice smooth running servos. Does anybody have any other ideas? I would like to do away with the relays, but they give good clean isolation of the RC pulses from the pulses sent by the Basic Stamp program.
Joe Fishback
You could arrange this so you check the left sensor, refresh servos, check right sensor, refresh servos, etc.
You're going to wear out the reed relays pretty quickly using them this way, I would think. They're only rated for like 100,000 operations, no?
You could also use a multi-plexor chip, so when the signal is high the RC control gets the servo, when low the BS2 gets the servos.
Note also the BS2 should refresh BOTH servos, THEN wait 20 mSec.· It's NOT refresh one, wait 20, refresh two, wait 20.· It's more like Refresh one, refresh two, wait 20, refresh one, refresh two, wait 20.
