shift registers & the javelin
I'm looking for some documentation on using the javelin with the 595 chips. I've read the manual and it has a simple example.. but its confusing for me.
I'd like to see how to code it so I'd know how to make.. say the 2nd pin of the 2nd 595 light a led. Most of what I've found has been examples showing counters and I cant understand how to relate the counter to make a certain pin on a certain 595 chip have an output.. what am I missing? I'm hoping to get this working and then run it through some optocouplers.. as I'd like to free up some pins.
Anybody have any examples?
Skank
Skank
I've attached a demo that shows how to use the '595 class.
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 1/25/2005 5:22:32 PM GMT
I’m a little confused..
here is what I'v come up with:
import stamp.core.*;
public class lightleds {
//map javelin to the 595chip pins
final static int DATA = CPU.pin0;
final static int CLOCK = CPU.pin1;
final static int LATCH = CPU.pin2;
public static void main() {
CPU.writePin(LATCH,false);
CPU.writePin(CLOCK,false);
CPU.writePin(DATA=,false);
while(true){
write595(1); //I'm guessing this will turn on a LED attached to Qa
CPU.delay(7500); //a little dalay
write595(17) //turns on LEDs attached to Qa & Qe?
} // end while
static void write595(int LEDpin){
CPU.shiftOut(DATA, CLOCK, 8, CPU.SHIFT_MSB, LEDpin <<8 );
CPU.pulseOut(32767, LATCH);
} // end write595
What if I want QA to remain on for longer than the pulseout limit of (32767 * 8.68us) units?
Jon Williams
Dallas, TX· USA
thanks Jon.. thats most helpful.
I started running out of pins on the breadboard so I could only hook up 4 LED's.. but if anybody else wants to get this working quickly maybe my picture will help..
Let's say you have two 595s, connected like this: Javelin --> A ---> B
What you do is output the value for unit B with the outNoLatch() method. This will actually put them into A and push what was in a into B. Now you output the value for unit A with the out() method. This pushes the values intended for B into in, moves the value for A into it, then latches the outputs of both units.
Trust me, it's more complicated to explain than it is to work with.
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 1/26/2005 3:28:24 PM GMT
