Tcp/ip & sx
does anybody know anything about a TCP/IP-Stack for the sx-chips? Google didn't help [noparse]:([/noparse]
Or UDP/IP? Or isn't it possible due to the speed and capabilities of the chip?
Thanks for your answers!
Thomas
PS: An other thing: I'm not really an electronics engineer so could you tell me if it is hard to somehow transform ~5V up to 12V? I'd like a SX-chip programming an other SX-chip...
Or do I need to supply the 12V? TIA!
Thomas
Go to:
www.sxlist.com/techref/scenix/virtperf.htm
...for info and source code for the TCP/IP stack that Scenix wrote for the SX48/52 chips.
Thanks, PeterM
Your looking for a DC-DC converter, since you only need to provide enough to program the chip it shouldn't be too difficult, I can't give you exact·guidance on which type to use because there are many (boost, buck, charge pump, flyback, PWM, switched capacitor). But the criteria your looking for is step-up, non-inverting 5V in, 12V out. But a quick check of the type "Flash Memory Converter" yeilds the LTC1262 and the MAX662. They are between $5 and $7 depending if you need 30mA or 60mA of programming current. Both are availible in 8-dip and 8-soic.
Paul
Thomas
