115200 Baud with BS2?
I have a 3 axis gyro out-put that is an ASC string with a data rate I can read at 115200 BPS, 8 bit, no-parity, 1 sotp bit·with a Hyperterminal.· Looking at the BS2 SERIN command reference to get 115200 BPS I end up with negative number?· I assume that means it won't read it?· Should I use a BS2sx or is there a front end data buffer I could utilize to make this work?· I saw some forum posts with BS2's communicating at 115200 but no details on how it was setup.· Any recommendations?
Can you adjust the gyro out-put slower?
Jon Williams
Dallas, TX· USA
