Help
Hi again.
I was wondering if the parallax cmu cam is programed in basic or in java like the other cmu cam. Anyone have ideas? Also I am trying to build a pool ball machine that sorts two green balls from the others, then sorts the others by solid/stripe. You can see my original post at
http://forums.parallax.com/forums/default.aspx?f=5&m=60310 .
So would the cmu cam work? Or can it only sort color? And also is this even possible to program into the bs2? All ideas/comments appreceated.
Egert the asuylum escapee
Links:
www.soinc.org/robobilll
http://soinc.org/robobill/robobill05.pdf
And on page 3 that is what I have to do.
A CHAIN IS ONLY AS STRONG AS ITS WEAKEST LINK
GENIUS IS 1% INSPIRATION AND 99% PERSPIRATION
THERE IS ALWAYS GOING TO BE ONE PERSON RICHER THAN YOU, UNLESS YOUR NAME IS BILL GATES
What is is, what is not is not, isn't it?
It is.
Links:
It is.
