No basic stamp found
I don't know what I did every time I try to download somthing to the bs2 it gives me this error message .
I don't know if it is the seral cable, the board of education or the stamp. but it still runs the progarm that is in the the stamp tho. the only thing that I can think of that happen I blew something with static electrcity.·Theres new batterys in it so it can't be that.·Can Ido anything or should I·just by the usb board ?
You'll need to take a few voltage measurements.· Make sure that you have your power connected and your cable connected to the PC.· You should measure·-5v on Sout pin·in reference to Vss(ground).· Then you should have·· -10v on the Sin pin·to Vss.· Your Rst should be at·5v along with your Vdd.· If these measurements are not present, please call tech support at 1-888-997-8267 with your set up ready to test.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
Post Edited (Dave Andreae (Parallax)) : 1/22/2005 10:03:26 PM GMT
thx
