A/D Converter
Hello,
···· I'm new at using the BASIC Stamp and its components. I'm trying to convert a voltage input to a digital signal using the the A/D converter.· I'm confused on the some of the pinouts on the A/D.· Any help would be appreciated.· Thanks
············· ····· CS··· Vcc·············CLK·· Vdd····· ··
··Input········· CH0····CLK············ U/D·· CS··············· Output
··Voltage······ CH1··· Dout···········A1···· B1·················Resistance
················· ·GND··· Din·············GND·· W1·
···················· A/d Conv··········· Digital Pot
·I understand·the digital potentiometer mostly from the "Whats a microcontroller " excercises although I could use a·better·description of the·A1 and B1 port funtions.·The A/d controller is not covered and the example programs·from the site·are too advanced for me to understand at this point. I have a·short time to get something going so any help would be appreciated. I have a workstation setup with DC Power supply and multimeter so if i could get a basic·setup I could figure it out from there. Thanks for the help··
It explains in detail how to hook up the A/D to the BSI or II or PIC, and even gives example code.
http://www.parallax.com/dl/docs/prod/appkit/ltc1298.pdf
or this article from Nuts and Volts:
ftp://nutsvolts.com/stampaps/st_ap4.pdf
Post Edited (Boris) : 1/21/2005 5:56:22 PM GMT
