IF ELS and Labels
I am a newby getting myself acqquainted with the BS2, but I ahve a bit of programming expereince.
I am trying to create a simple if else statement and I keep getting error 148 asking for a label.
What is a label? It is not something I have run across in any other programming language.
Here is what I am trying to do:
' {$STAMP BS2}
' {$PBASIC 2.0}
INPUT 6
OUTPUT 7
Main:
LOW 7
IF (IN6 = 1) THEN
HIGH 7
Else
LOW 7
END
GOTO main
The exception to this is if you write:
if in0 =0 then high 5
With a one-line command you do not need the endif.
Sid Weaver
Do you have a Stamp Tester?
Second: PBASIC 2.5 lets you define an IO pin as a PIN, and can simplify syntax.· Thus, your example becomes:
' {$STAMP BS2} ' {$PBASIC 2.5} Ctrl PIN 6 Led PIN 7 Reset: LOW Led ' make output and off Main: Led = Ctrl GOTO MainThe key is that the compiler knows that your pins are pins and coverts
Led = Ctrl
to:
OUT7 = IN6
You next logical question is: What if I want to change to an active-low input?· No problem· Change the line to:
Led = ~Ctrl
Jon Williams
Dallas, TX· USA
Many thanks!
