Javelin Socket Extraction
What is everyone's perferred method for extracting the Javelin from a socket? Because of the large amount of static friction holding the Javelin in you will end up making a quick jerky movement once it frees possibly damaging the pins. I've tried using an old plastic airplane propeller from my r/c planes to get underneath of one side and Torque it a littlebit to free one side and then Torque a little on the other side until it's free. This seems to be the most effective way I can get it out of the socket without damaging it. I don't think a CPU extraction tool would be any help here because of two reasons: Sensitive parts underneath the IC, and If one side Frees itself from the socket before the other you end up with One side of bent pins. Ideas? Thoughts? Suggestions? Stories?
